On 02/04/2011 11:57 AM, Andreas Ericsson wrote:
> On 02/04/2011 11:30 AM, Jochen Bern wrote:
>> It IIUC also means that during the downtime, the CGI-bins will keep
>> displaying the *historic* flapping state, along with the *current*
>> host/service state.
> Perhaps, but it should clear up fairly rapidly, and if a FLAPPING_START
> notification was sent out, I'd expect to get a FLAPPING_STOP one when
> repairs are done, assuming that happens after downtime has ended.
You don't have a guarantee to see post-downtime FLAPPING_STOPs right now
(because they're not exempt from being blocked by the downtime, and
because you'd have to skip any kind of testing the UP-again service and
manually delete the remaining downtime right away to completely avoid
the time gap). Same effect if a notification_period is used - I *did*
search for the "bug" when colleagues reported that, when following up on
a service they last got a FLAPPING_START from, they found a non-flapping
OK in the UI.
>> Downtime disables notifications anyway, and there already is logic to
>> trigger actions when downtime ends (*). IMHO, the proper way to provid=
e
>> a clean slate after a downtime would be to flush (**) the entire histo=
ry
>> at that point.
> Effectively lying about state history? No thanks.
You talk about lying, I talk about misleading. Deriving a flapping flag
from a state history whose entries hail from way in the past - no matter
whether updates were blocked by downtime, check_interval, dependencies,
a forced reschedule into the distant future, or whatever - qualifies for
the latter.
>> (**) Whether the bins should be reset to OK, PENDING,
>> last-before-downtime or the current post-downtime $*STATE$ (if one is
>> already available) is up for discussion ...
> Current state will always be current state. I'm not going to change
> that, ever. Most of our customers regularly check the ui during repairs
> to see if the service is up and running as expected. Showing anything
> but the *real* current state there would be counterproductive for all
> nagios users.
You might want to note that I never asked for overwriting "the" current
state (rather than the history bins) in the first place. Matter of fact,
the UI's flapping marker being happily derived from a *stale* history is
sort of my main point.
Regards,
J. Bern
--=20
7
Unternehmenssitz Weiterstadt, Gesch=E4ftsf=FChrer Metin Dogan, Oliver Mic=
hel
