[Nagios-devel] Reproducible bug scheduling second host check
----=_pe3dn3tqn1atl8stbn0ahg4pjguvcu0v1l.MFSBCHJLHS
I have, for some time, been suspicions that Nagios 3 appeared a bit slow
alerting on host failures. In order to diagnose this, I setup a minimal
config to try to show the problem using 3.0rc1 with a default nagios.cfg.
It consists of one host and one service (both checked by ping), with the
retries and timers set as below (the config file is attached in full):-
|define host{
| host_name hostname
| check_interval 10
| retry_interval 1
| max_check_attempts 5
|define service{
| normal_check_interval 5
| retry_check_interval 5
| host_name hostname
| service_description ping
The host was up at 16:25 with the next host check scheduled for 16:35 and
the next service check for 16:30:-
|[2007-12-29 16:25:42] [1198945542.102847] [016.0] [pid=3660] Scheduling a non-forced, active check of service 'ping' on host 'hostname' @ Sat Dec 29 16:30:32 2007
|[2007-12-29 16:25:52] [1198945552.201392] [016.1] [pid=3660] Pre-handle_host_state() Host: hostname, Attempt=1/5, Type=HARD, Final State=0
|[2007-12-29 16:25:52] [1198945552.201763] [016.0] [pid=3660] Scheduling a non-forced, active check of host 'hostname' @ Sat Dec 29 16:35:52 2007
The host was then unplugged and the service was checked as expected at
16:30. As the service was down, the host (again as expected) was checked.
The next host check was scheduled for 16:32 as expected with the host
retry_interval of 1 minute:-
|[2007-12-29 16:30:32] [1198945832.178688] [016.0] [pid=3660] Attempting to run scheduled check of service 'ping' on host 'hostname': check options=0, latency=0.178000
|[2007-12-29 16:30:52] [1198945852.109282] [016.1] [pid=3660] HOST: hostname, SERVICE: ping, CHECK TYPE: Active, OPTIONS: 0, SCHEDULED: Yes, RESCHEDULE: Yes, EXITED OK: Yes, RETURN CODE: 2, OUTPUT: CRITICAL - Host Unreachable (m18.itconsult.net)
|[2007-12-29 16:30:52] [1198945852.109557] [016.1] [pid=3660] Service is in a non-OK state
|[2007-12-29 16:30:52] [1198945852.109579] [016.1] [pid=3660] Host is currently UP, so we'll recheck its state to make sure...
|[2007-12-29 16:30:52] [1198945852.109626] [016.0] [pid=3660] ** Running async check of host 'hostname'...
|[2007-12-29 16:30:52] [1198945852.127798] [016.0] [pid=3660] Scheduling a non-forced, active check of service 'ping' on host 'hostname' @ Sat Dec 29 16:35:32 2007
|[2007-12-29 16:31:02] [1198945862.209380] [016.1] [pid=3660] Pre-handle_host_state() Host: hostname, Attempt=1/5, Type=SOFT, Final State=1
|[2007-12-29 16:31:02] [1198945862.210709] [016.0] [pid=3660] Scheduling a non-forced, active check of host 'hostname' @ Sat Dec 29 16:32:02 2007
|[2007-12-29 16:31:02] [1198945862.210735] [016.2] [pid=3660] Found another host check event for this host...
|[2007-12-29 16:31:02] [1198945862.210760] [016.2] [pid=3660] Keeping original host check event (ignoring the new one).
|[2007-12-29 16:31:02] [1198945862.210831] [016.1] [pid=3660] ** Async check result for host 'hostname' handled: new state=1
However, although the CGIs continued to show the next host check for 16:32,
nothing happened until:-
|[2007-12-29 16:35:32] [1198946132.119030] [016.0] [pid=3660] Attempting to run scheduled check of service 'ping' on host 'hostname': check options=0, latency=0.118000
|[2007-12-29 16:35:42] [1198946142.223011] [016.0] [pid=3660] Scheduling a non-forced, active check of service 'ping' on host 'hostname' @ Sat Dec 29 16:40:32 2007
|[2007-12-29 16:35:52] [1198946152.053988] [016.0] [pid=3660] Attempting to run scheduled check of host 'hostname': check options=0, latency=0.053000
|[2007-12-29 16:35:52] [1198946152.054042] [016.0] [pid=3660] ** Running async check of host 'hostname'...
|[2007-12-29 16:36:02] [1198946162.152677] [016.2] [pid=3660] Host has no parents, so it is DOWN.
|[2007-12-29 16:36:02] [1198946162.152699] [016.1] [pid=3660]
...[email truncated]...
