Re: [Nagios-devel] Nagios 2 quitting
do a search for RLIMIT_CORE in utils.c and delete the setrlimit call.
then in the shell before you call nagios do
ulimit -c unlimited
this should let nagios actually dump core and then you can see what is
causing it.
--Ian
hey Ethan.. what is the logic behind disabling cores in the code like
this instead of using ulimit?
On Tue, 10 Aug 2004 07:58:52 -0700, Jason Martin wrote:
> On Tue, Aug 10, 2004 at 08:06:26AM -0500, Justin Lambert wrote:
> > out of the log file - is there a way to turn on more logging so I can
> > get some more info?
> If you compile in debugging you'll get a lot more info on where
> the failure occured.
> -Jason Martin
> Alexander the Grape: He Concord the world.
> This message is PGP/MIME signed.
