Mathieu Gagné wrote:
> Hi,
> On 5/14/09 3:43 AM, Gerhard Lausser wrote:
>> i reported this bug in january
>> http://archive.netbsd.se/?ml=nagios-dev ... &m=9671673
>> http://archive.netbsd.se/?ml=nagios-dev ... &m=9671670
>> Imo, the condition for the second unlink needs to be reversed.
> I think I found the source of the problem.
> In base/checks.c, delete_check_result_file() is called within
> reap_check_results():
> - From "/* service check */" at line 167 if it's a service checkresult
> for an unknown service or
> - From "/* host check */" at line 192 if it's a host checkresult for an
> unknown service or
> - at line 211 if it's processed normally.
> However Nagios calls delete_check_result_file() in base/utils.c at line
> 2486 too in process_check_result_queue() which is itself called from
> base/checks at line 149 in reap_check_results() BEFORE the first case I
> mentioned.
> So basically it does:
> /* For each files in checkresult */
> process_check_result_file()
> add_check_result_to_list()
> Service: handle_async_service_check_result()
> Host: handle_async_host_check_result_3x
> Since process_check_result_queue() has already loaded all checkresult
> files in a list in memory (by calling add_check_result_to_list() in
> process_check_result_file()), reap_check_results() shouldn't call
> delete_check_result_file() at all.
> Does it make any sense to you?
Yes, but it seems unnecessarily complex. I think I'll revamp it so
it's read once and deleted immediately after.
OP5 AB www.op5.se
Register now for Nordic Meet on Nagios, June 3-4 in Stockholm
http://nordicmeetonnagios.op5.org/
on peace.
