Re: [Nagios-devel] Nagios and Gearman - huge environment performan=
--_000_4288A518A157EC4C8873FEE74F778BF0022980WPSDGQHHOPRSTATEF_
Content-Type: text/plain; charset="iso-8859-1"
Well but look at your bi and bo, and then the wa column. So looks like you=
have some IO Wait which probably means it's waiting on disk activity to ge=
t things done, and lots of writing to disk. Have you looked at adding a ra=
mdisk for your checkresults, status.dat, and temp_file? That should help e=
liminate most of the heavy disk i/o from the nagios perspective. Since it =
doesn't look like you are swapping memory you should be able to throw some =
at a ramdisk. You can probably start with 64MB and watch it, might have to=
go higher depending on your workload.
Dan
Sent: Friday, August 19, 2011 11:27 AM
To: Nagios Developers List
Subject: Re: [Nagios-devel] Nagios and Gearman - huge environment performan=
ce problem
Hi, Daniel,
As we can see below, I think it is not a hardware problem. The idle CPU is =
beteween 60 and 80 %, very good.
Thank you very much.
$ vmstat 5
procs -----------memory---------- ---swap-- -----io---- --system-- -----cpu=
r b swpd free buff cache si so bi bo in cs us sy id =
wa st
1 2 22092 3046788 189640 890940 0 0 295 1053 0 0 4 3 83=
10 0
1 2 22092 3032992 189664 904600 0 0 2733 7550 3498 7477 12 1 69=
18 0
1 2 22092 3018240 189668 918632 0 0 2720 4070 2484 5114 13 1 72=
15 0
1 0 22092 3008312 189668 930336 0 0 2332 1534 1932 3825 13 1 73=
14 0
1 18 22092 2979292 189724 945780 0 0 1486 13974 2460 8446 16 2 72=
10 0
1 2 22092 2965244 189736 959228 0 0 2570 9094 3290 7204 13 1 67=
19 0
1 2 22092 2949064 189748 973100 0 0 2820 3040 2798 6639 13 2 68=
17 0
1 6 22092 2936060 189768 987788 0 0 2894 3620 2474 5443 13 1 70=
16 0
1 1 22092 2923320 189780 999708 0 0 2377 2618 2285 4794 13 1 70=
16 0
1 0 22092 2923428 189780 999964 0 0 0 4575 1732 2317 12 1 86=
1 0
1 9 22092 2912192 189784 1005260 0 0 402 4544 1541 3889 14 1 8=
2 3 0
1 7 22092 2891692 189808 1023020 0 0 2534 13969 3232 9421 14 2 6=
6 17 0
3 2 22092 2868908 189836 1037064 0 0 2797 4115 3002 7055 30 2 5=
4 14 0
2 2 22092 2860712 189860 1050376 0 0 2646 3352 2448 5416 16 1 6=
7 17 0
1 8 22092 2847052 189872 1064036 0 0 2748 3970 2616 5487 13 1 6=
9 17 0
1 0 22092 3469576 189876 462624 0 0 825 1245 1379 2098 12 1 83=
5 0
1 0 22092 3469248 189884 462720 0 0 4 2631 1552 2599 13 0 86=
0 0
1 20 22092 3449816 189904 482192 0 0 2404 8454 2293 7764 15 2 70=
12 0
1 17 22092 3434856 189912 495636 0 0 2694 8955 3542 8039 13 2 65=
19 0
2 7 22092 3422204 189932 509376 0 0 2742 4059 2685 5826 13 1 68=
19 0
1 13 22092 3407532 189948 522508 0 0 2661 3613 6447 49867 12 4 6=
6 17 0
0 0 22092 3404484 189968 525964 0 0 669 3338 5317 43602 10 4 8=
1 6 0
1 0 22092 3402004 189984 525956 0 0 0 14 3637 12700 13 1 8=
5 0 0
1 0 22092 3398172 190012 526036 0 0 0 3318 3972 12401 14 1 8=
5 0 0
2 0 22092 3392628 190028 526048 0 0 0 9331 5347 16423 15 3 8=
1 1 0
4 0 22092 3391704 190048 526060 0 0 0 4270 5785 18736 16 2 8=
0 1 0
1 1 22092 3391652 190064 526056 0 0 0 4091 4746 14669 16 2 8=
2 1 0
1 0 22092 3392104 190068 526056 0 0 0 1562 4037 11849 16 1 8=
3 0 0
3 0 22092 3392304 190084 526168 0 0 1 2532 4618 16418 15 2 8=
3 0 0
1 7 22092 3386028 190112 531488 0 0 967 363 4194 14941 15 2 7=
7 6 0
On Fri, Aug 19, 2011 at 11:32 AM, Daniel Wittenberg > wrote:
> One simple thing that might help is just run vmstat for a couple minutes:
> vmstat 5
> That can help show if you are hitting some bottlenecks. Are you using a =
lot of macros in your
...[email truncated]...
Original poster: odney Ramos [mailto:[email protected]
