Re: [Nagios-devel] =?ISO-8859-1?Q?R=E9f=2E_=3A_Nagios-devel_?=
Ben wrote:
> Actually, it occured to me that this wouldn't be a problem if nagios'
> #defines were simply in a file not needed by NEB modules.
The real solution would be to fix glib though. It's rude to export such
common-place macros. There's a reason POSIX throws in a _t for all their
type-declarations and gcc has double underscores for internal macros.
> Yann DIRSON wrote:
>> I guess the following would do the job:
>> #if ((TRUE != 0) && (FALSE == 0))
>> Message: 4
>> From: "Ethan Galstad"
>> To: [email protected]
>> Date: Sun, 17 Apr 2005 23:31:28 -0500
>> Subject: Re: [Nagios-devel] TRUE and FALSE
>> That could be done. Is there a #if-like statement to only do this if
>> TRUE=1 and FALSE=0? I wouldn't want TRUE and FALSE being set to
>> something else, lest bad things happen...
>> On 5 Apr 2005 at 14:12, Ben wrote:
>>> I'm making a NEB module that will rely on glib, which defines TRUE and
>>> FALSE. Nagios also defines TRUE and FALSE in include/common.h.
>>> Predictably, the compiler is unhappy when I try to compile my NEB.
>>> Ethan, do you have a problem wrapping your TRUE/FALSE defines in an
>>> #ifndef TRUE test?
>> This SF.Net email is sponsored by: New Crystal Reports XI.
>> Version 11 adds new functionality designed to reduce time involved in
>> creating, integrating, and deploying reporting solutions. Free runtime
>> info,
>> new features, or free trial, at: http://www.businessobjects.com/devxi/728
>> _______________________________________________
>> Nagios-devel mailing list
>> [email protected]
>> https://lists.sourceforge.net/lists/lis ... gios-devel
> info,
> [email protected]
OP5 AB www.op5.se
Lead Developer
