[Nagios-devel] Problems building NRPE 2.12 on HPUX 11.23 Itanium
As a followup/addendum to my previous message, I thought I'd add some
comments on issues I've had building NRPE 2.12 on HPUX 11.23 for
Itanium.
The issues are the same as with building NRPE 2.12 on HPUX 11.23 PA-RISC
with one notable exception. I've had this issue since NRPE 2.6.
Assuming I've made the changes I referenced in my message regarding
building on 11.23 PA-RISC, I would then get the following after doing a
"make".
$ make all
cd ./src/; make ; cd ..
cc -g -I/usr/include/openssl -I/usr/include
-DHAVE_CONFIG_H -c ./snprintf.c
(Bundled) cc: warning 922: "-g" is unsupported in the bundled
compiler, ignored.
-DHAVE_CONFIG_H -o nrpe nrpe.c utils.c -L/usr/freeware/lib/openssl
-lssl -lcrypto -lnsl -lwrap ./snprintf.o
compiler, ignored.
nrpe.c:
Warning 942: "nrpe.c", line 852 # Types 'int *' and 'unsigned
long *' are not
assignment-compatible.
=09
rc=3Dgetpeername(new_sd,&addr,&addrlen);
=09
utils.c:
ld: (Warning) Unsatisfied symbol "rfc931_timeout" in file
/usr/lib/hpux32/libwrap.so
1 warnings.
-DHAVE_CONFIG_H -o check_nrpe check_nrpe.c utils.c
-L/usr/freeware/lib/openssl -lssl -lcrypto -lnsl
compiler, ignored.
check_nrpe.c:
utils.c:
*** Compile finished ***
(This particular Itanium box also has HP's gcc on it, but it still
chokes on the missing rfc931_timeout).
This missing "rfc931_timeout" caused me some frustration. I could not
find it anywhere on this platform.
Ultimately, my workaround (again, somewhat clunky, but it works) was to
grab this function from the latest tcp_wrappers code I could find
(tcp_wrappers 7.6) and add it to this directory. I now have an
'rfc931.c' in my nrpe-2.12/src directory.
I then modified src/Makefile (manually, after running 'configure') as
follows to get it to build:
$ diff ../src.old/Makefile Makefile
12c12
CFLAGS=3D-g -I/usr/include/openssl -I/usr/include
-DHAVE_CONFIG_H -DRFC931_TIMEOUT=3D10
36,37c36,39
rfc931.o:
> nrpe: nrpe.c utils.c $(SRC_INCLUDE)/nrpe.h
$(SRC_INCLUDE)/utils.h $(SRC_INCLUDE)/common.h $(SRC_INCLUDE)/config.h
$(SNPRINTF_O) rfc931.o
> $(CC) $(CFLAGS) -o $@ nrpe.c utils.c $(LDFLAGS)
$(SOCKETLIBS) $(LIBWRAPLIBS) $(SNPRINTF_O) $(OTHERLIBS) rfc931.o
When compiling, I still get similar warnings as with PA-RISC:
$ make
-DHAVE_CONFIG_H -DRFC931_TIMEOUT=3D10 -c ./snprintf.c
compiler, ignored.
-DHAVE_CONFIG_H -DRFC931_TIMEOUT=3D10 -o nrpe nrpe.c utils.c
-L/usr/freeware/lib/openssl -lssl -lcrypto -lnsl -lwrap ./snprintf.o
rfc931.o
compiler, ignored.
nrpe.c:
long *' are not
=09
=09
utils.c:
-DHAVE_CONFIG_H -DRFC931_TIMEOUT=3D10 -o check_nrpe check_nrpe.c utils.c
compiler, ignored.
check_nrpe.c:
utils.c:
But the resulting nrpe binaries does work perfectly as far as I can see.
Wanted to pass this info along.
Mark
