Great, thanks.
After a quick scout through the documentation I found what you were talking
about mentioned in the problem escalation section (though it doesn't appear
at all in the list of options for the service section) - the variable is
actually "contact_groups".
It now works, thanks for your help.
Ewan
> -----Original Message-----
> From: Ethan Galstad [mailto:[email protected]]
> Sent: 03 January 2002 00:57
> To: [email protected]
> Subject: RE: [Nagios-devel] Service notification commands not being
> execut ed
> The problem is due to the fact that you don't have any contact groups
> defined for the service. The fact that you didn't get any warnings
> about this is a bug on my part. I'll also fix the code so that the
> notification number doesn't get incremented if there aren't any
> contacts who get notified. Add something like 'contactgroup aix-
> admins' to the service definition and you should be okay.
