Re: [Nagios-devel] CPU leak on nagios-2.0b2
Hi!
On Thu, Feb 24, 2005 at 12:29:17PM +0100, Andreas Ericsson wrote:
> >We are try use nagios-2.0b2 for active monitoring ~500 services every 2
> >min.
> Usually it isn't necessary to run checks every 2 mins, since this puts a
> considerable load on the system (500/120 = 4.1 checks always running
> simultaneously). See if you can put disk-checks stuff that doesn't
> usually change very rapidly on a less frequent schedule. 15-30 minutes
> should be enough. load and such (which uses average values anyway) can
> also be checked less frequently.
Yes, I know. But it's our specific.
This is only part of distributed scheme.
And we are need minimal latency of monitoring system (now we have 5-min latency).
> >It's PIII-730MHz with 512 Mb of memory.
> >Summary CPU load on this machine ~30% (we are looking on OIDs:
> >enterprises.ucdavis.systemStats.ssCpuRawSystem.0
> >enterprises.ucdavis.systemStats.ssCpuRawUser.0
> >) with SystemCpuLoad prevail.
> >After 24 Hours summary CPU load on this machine ~85%.
> 85% CPU load is equivalent (roughly) to 0.85 as reported by uptime.
No.
load average: 2.70, 2.80, 2.80
> The simplest and cheapest way is to raise the default check interval and
> require less checks before a service enters hard state.
> You can also make sure no un-necessary programs are running on the
> server (like X-windows or a heavily loaded web/database server).
> The most expensive and cumbersome way is to buy new hardware. Avoid this
> if it can be helped at all.
If we have stable load ~80% -- no problem.
But CPU load _increased_ from 30% when we started nagios to 80% during 24 hours approx.
Dmitriy Kirhlarov
OILspace, 4, B. Spasskaya str. room 01, 107978 Moscow, Russia
P:+7 095 787 4700 F:+7 095 787 4701 E:[email protected]
OILspace - The resource enriched - www.oilspace.com
