thanks for the fast response
Andreas Ericsson wrote:
> It's been discussed and decided. The consensus is that we will as soon
> as Ethan has
> time to look through git and learn it to an acceptable level so he
> feels comfortable
> with it. Me and Ton are just waiting for the go-ahead, which we hope
> will come rather
> soon.
I'm pretty aware of the waiting period. It's more or less a repeated
question blown into the dev cloud
It's just an idea of sharing patches easier. I like those GIT mirrors
available for public usage, but it's more overhead than having a single
official Nagios GIT repository, cloning that next my icinga-core.git and
if possible, backport patches and enhancements. And if more people would
get commit access to their respective heads (as we do in Icinga) this
would be easier too - just fetch latest commits and merge to a staging
branch for more testing (e.g. you or Ton or Ethan then). As said, just
an idea as we are all more or less core hackers with different problems,
than a scm should cause imho.
> In the meantime, we both maintain git repositories with separate
> branches for our
> own development. Mine is rebased onto master every once in a while, so
> it shouldn't
> be considered a stable base for development.
> You'll find mine at
> git://git.op5.org/nagios.git dev
> I'll rebase that one later today though, and possibly submit the patches to CVS
> via the export-commit functionality in git.
Yep, i've evaluated and partly merged them. Some caused problems (neb
module my_fcopy hacks, when loading more than one module), but I did not
get the time to look deeper into them. Although I will after getting
Icinga release done and stepping onto unstable branch. I'll get back to
you then
Kind regards,
Michael
DI (FH) Michael Friedrich
Vienna University Computer Center
Universitaetsstrasse 7 A-1010 Vienna, Austria
email: [email protected]
phone: +43 1 4277 14359
fax: +43 1 4277 14279
web: http://www.univie.ac.at/zid
Icinga Core& IDOUtils Developer
http://www.icinga.org
