On 06/20/2012 11:40 PM, Jochen Bern wrote:
> On 05/24/2012 11:30 AM, Andreas Ericsson wrote:
>> On 05/18/2012 12:52 AM, Jochen Bern wrote:
>>> On 05/11/2012 09:34 PM, Jochen Bern wrote:
>>>> Everyone,
>>>> I played with the "-c" and "-s" Parameters of a 3.2.3's nagiostats today
>>>> and noticed the odd behavior shown below. [...]
>>> Any chance that the -s option might be reappropriated to read the
>>> current status.dat files via read_status_file(), rather than a format
>>> lost in the sands of time ... ?
>> Sounds like you've already done a large part of the analysis, so it might
>> be good if you did the patch as well.
> Very well. The attached patch is for 3.2.3, which is what I have at hand
> right now both source- and real-world-example-data-wise. Does it happen
> to apply cleanly to 3.4.1 ... ?
It might. nagiostats hasn't been changed in a very long time. I'll try
and find out.
OP5 AB www.op5.se
on peace.
