On Wed, 13 Apr 2005, Dietmar Ruzicka wrote:
> Hi,
> I am currently writing my diploma thesis at the TU Vienna. A part of my work
> is a mysql database interface for nagios. The plan is to develop a databse
> interface which supports almost everything. This means every information,
> which is currently found in the configuration files, the status files, .. is
> written and read from the database. I do this from the scratch based on
> nagios 2.0b2.
> The current status is very pre alpha. The configuration is almost finished,
> excluding the nagios.cfg itself. The configuration tables are based on the
> current text configuration, describe in the documentation, excluding the
> template options. The current state of host and services hold in the memory
> of the nagios-core is written to the database too and almost finished. This
> shall replace the retention, status and objects.cache files and is necessary
> for the webinterface. Comments and downtime information is hold in the
> database too. The changes in the webinterface is just started. An optional
> replacement for the nagios.cmd is also included.
> The database support should be option to the usual text-based way, which can
> be activated or deaktivated during the configure step.
> I am currently using Nagios in a kind of mixed mode. Almost all parts of
> Nagios-core are using the database, but for the most parts of the
> webinterface the information is read from the text-files, except
> configuration, comments, notifications and scheduling queue. Therefor I
> write the informations to the database and to the text-files.
> What Do you think, is this a usable idea?
> regards
> Dietmar
It would be better if you could separate the code for the configuration
data from the status data. A better place to hook in for status data
(including acknowledgement and downtime) is the new NEB module and its
use as demonstrated by the nagios-db project.
With the config data going into a database, it important to verify
consistency of the data with respect to nagios's data structures. yes
Nagios does that on startup, but the UI to manage the data entry should
also do verification.
-sg
