[Nagios-users] Re: [Nagios-devel] Bug: NSCA 2.4 on OS X 10.3 (Was: NSCA daemon never writes to nagios.cmd or nsca.dump)
--J/zg8ciPNcraoWb6
Content-Disposition: inline
Noah Leaman said on Tue, Jan 27, 2004 at 02:06:35AM -0800:
> >Yup. 131K seems to be an awful lot but it could certainly be attributed
> >to the encryption method you are using. Just as a test, I would=20
> >probably
> >try using just simple XOR.
>=20
> It was and still is set to XOR... decryption_method=3D1
=20
Try turning off encryption entirely for now; until there's data flowing,
there's no point in making it harder to figure out what's going on.
> The send_nsca command takes less than a second to run and finish so I=20
> dont think it's that. How do I enable debug on remote server? I added a=
=20
> debug=3D1 to the send_nsca.cfg file but it complains with a "Unknown=20
> option specified" when running send_nsca. The ktrace I sent you is with=
=20
> XOR.
=20
send_nsca doesn't support debug in its config file AFAIK.
> When I run the send_nsca comand manually it replies with:
> 0 data packet(s) sent to host successfully.
>=20
> Is that normal? should it be 0 data packets? There is no packet loss=20
> between the systems.
No, that should say 1 data packet(s).
> I have setup nsca on another OS X 10.3 system and tried to get it to=20
> work by sending from the same system that the nsca daemon is running on=
=20
> and I get the same problem.
>=20
> To manually send it I used:
>=20
> /bin/echo -e "host.domain.com\tPing\t0\tPING OK - Packet loss =3D 0%, RTA=
=20
> =3D 443.71 ms\n" | /Users/noah/nsca/send_nsca -H 127.0.0.1 -c=20
> /Users/noah/nsca/send_nsca.cfg
>=20
> I attached an unedited ktrace/kdump output of exactly one send_nsca=20
> command in case it helps at all.
Can you turn off encryption, and ktrace both nsca and send_nsca at the same
time?
M
--J/zg8ciPNcraoWb6
Content-Type: application/pgp-signature
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.2.3 (FreeBSD)
iD8DBQFAFq2SOtZWu2tc1lARAqmCAKCAxkw6EXBhH9EhOKLx3zrIR+zLXwCfcF+k
3kvk+GmUGRXv8o7uS4WdCNc=
=Z20z
-----END PGP SIGNATURE-----
--J/zg8ciPNcraoWb6--
The SF.Net email is sponsored by EclipseCon 2004
Premiere Conference on Open Tools Development and Integration
See the breadth of Eclipse activity. February 3-5 in Anaheim, CA.
http://www.eclipsecon.org/osdn
_______________________________________________
Nagios-users mailing list
[email protected]
https://lists.sourceforge.net/lists/lis ... gios-users
::: Please include Nagios version, plugin version (-v) and OS when reporting any issue.
::: Messages without supporting info will risk being sent to /dev/null
