Re: [Nagios-devel] Nagios 3.0 RC2: Segmentation
This is a cryptographically signed message in MIME format.
--------------ms080300000104020100020809
Content-Type: text/plain; charset=UTF-8; format=flowed
Olaf Dabrunz schrieb:
> On 14-Feb-08, Hendrik B=C3=A4cker wrote:
>> Christian Schneemann schrieb:
>>> And here some more background info:
>>> nagios is compiled with --enable-embedded-perl and embedded perl is=20
>>> deactivated in thte nagios.cfg.=20
>>> If I enable it in the nagios.cfg nagios runs fine without segfaulting=
=2E Do you=20
>>> have any ideas?
>> ?=C2=BF?
>> If you _enable_ ePN there is _no_ segfault??
>> As far as I see the segfaulting code segment has nothing to do=20
>> with/without ePN.
>> *confused*
>=20
> The problem is that --enable-embedded-perl will cause libperl to be
> linked in before libc. This means that the opendir() and readdir() in
> process_check_result_queue() will be linked in from libperl, instead of=
> libc. The libperl versions will only work when the embedded perl is
> initialized as well.
>=20
> Linking problem.
>=20
> (Please mail replies to me personally, as I am not on this list.)
>=20
> Regards,
>=20
Ooops, just for me to know.
Would it be solved just by re-arange from (base/Makefile):
nagios: nagios.c ....
$(CC) [flags and co] $(PERLLIBS) ... $(LIBS)
to s.th. like:
$(CC) [flags and co] $(LIBS) $(PERLLIBS) ...
Please don't hit me but I got curios with this behavior.
Hendrik
Content-Type: application/x-pkcs7-signature; name="smime.p7s"
Content-Disposition: attachment; filename="smime.p7s"
Content-Description: S/MIME Cryptographic Signature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...[email truncated]...
