Hi to all, and Happy New Year.
On 2004-12-13 22:26, Ethan Galstad wrote:
> I"ll check into modifying the code to do this during the 2.0 beta
> process, but I"m not convinced I want to muddle with the CGIs much
> anymore unless there are real bugs.
On the nagios-users list, there's a thread that points out a bug that affects
the "Service State Trends". From a post by Eric Bollengier:
----------------- quote
[1099042385] SERVICE ALERT: test;ssh;CRITICAL;SOFT;1;Connection refused
[1099042445] SERVICE ALERT: test;ssh;CRITICAL;SOFT;2;Socket timeout
[1099042525] SERVICE ALERT: test;ssh;CRITICAL;HARD;3;Socket timeout
[1099042715] HOST ALERT: test;DOWN;SOFT;1;CRITICAL
[1099042725] HOST ALERT: test;DOWN;SOFT;2;CRITICAL
[1099042735] HOST ALERT: test;DOWN;SOFT;3;CRITICAL
[1099042745] HOST ALERT: test;DOWN;SOFT;4;CRITICAL
[1099042755] HOST ALERT: test;DOWN;HARD;5;CRITICAL
[1099042755] SERVICE ALERT: test;ping;CRITICAL;HARD;1;CRITICAL
[1099042935] HOST ALERT: test;UP;HARD;1;PING OK
[1099042935] SERVICE ALERT: test;ping;OK;HARD;1;PING OK
[1099042945] SERVICE ALERT: test;ssh;CRITICAL;SOFT;1;Socket timeout
[1099043005] SERVICE ALERT: test;ssh;OK;SOFT;2;TCP OK
====> BUG ssh is in CRITICAL HARD STATE, but OK is SOFT !!
----------------- end quote
I've had this same thing happen to me, though with a different service. The
result is a 5 day 8 hour block of "critical" in my report unless I edit the
proper log file and change the SOFT to HARD.
Either fixing the real problem OR including SOFT states in reporting would show
the correct states.
--Kristian
Kristian Strickland, BSc Math & CompSci (StFX '94)
IBM (e)server Certified Specialist:
-> pSeries AIX System Administration -> pSeries AIX System Support
System Support Specialist (AIX, OpenVMS & FreeBSD) for
Co-op Atlantic in Moncton, NB, Canada
My Books:
AIX admin: http://www.redbooks.ibm.com/abstracts/sg246191.html
AIX support: http://www.redbooks.ibm.com/abstracts/sg246199.html
Please R.U.N.S.A.F.E.
http://www.jmu.edu/computing/runsafe
