Alessandro Ren wrote:
> Attached is a patch for nagios-2.0 final that fixes the problem in
> avail.cgi that does't show the schedule downtimes in the reports.
> All changes are done in the function compute_subject_downtime_times
> in cgi/avail.c code.
> Any feedbacks on the patch are aprechiated. It is working for me so far.
> The fixed function can also be appllied to earlier versions, I have
> also tested in 1.x nagios version and it has worked fine and so in the
> 2.0 beta versions.
Could you resend this patch in unified diff format, please?
Just recreate it with your current directory structure and the command:
diff -urN nagios-2.0 nagios-2.0-patched > sched-downtime.diff
and send sched-downtime.diff to the list.
OP5 AB www.op5.se
