Content-Type: text/plain; charset=ISO-8859-1
Content-Disposition: inline
Dear Andreas,
Thanks for your answer. I had a look to the code (for the first
time), and I did a patch, which was too easy in my opinion. Please
find attach the modification I did, the xodtemplate_duplicate_services
looked like the only function to modify to me.
I built Nagios and it runs without problem so far, with the expected behavior.
Sorry if the patch is stupid, I'm not yet familiar with Nagios
code... I guess the only side effect is that it might break some
service duplication checks that were done before.
Your opinion will be very much appreciated !
LB
On Tue, Nov 11, 2008 at 11:03 AM, Andreas Ericsson wrote:
> L B wrote:
>> Hello,
>> I have many nagios servers for different regions in the world, and I
>> want to create a standard installation with a set of hostgroups,
>> commands, and services with default thresholds, for all my Nagios
>> admins. My services are applied to hostgroups, and I want to add a
>> check to a host only by adding this host to the relevant hostgroup.
>> Example :
>> - I define a command check_dns
>> - I define a hostgroup dns-server-hostgroup
>> - I define a service check_dns applied to dns-server-hostgroup
>> Then I define a host, and if it's a DNS server, I add it to the DNS
>> hostgroup (I'm running Nagios 3):
>> define host {
>> hostgroups +dns-server-hostgroup
>> This works very well in my configuration except that if I install a
>> nagios server in a new region, and they not have for example a NFS
>> server, I will get an error because nfs-server-hostgroup is empty. I
>> fixed this by adding "register 0" to the service definition, but that
>> means the admins have to comment out this line to enable the check on
>> the hostgroup.
>> So I would like to be allowed to create checks on empty hostgroups,
>> and of course if the hostgroup is empty, no check is done.
>> Is there something technically in the nagios core that prevents
>> creating empty hostgroups
> No, but when a service is assigned to a hostgroup, that hostgroup
> is already expanded (and found to contain zero hosts), so the service
> is assigned to no host at all, but still doesn't have "register 0"
> in it, so it's a faulty service.
>> or is it an arbitrary configuration check
>> because it's assumed that a user probably doesn't want to check a
>> service on a empty hostgroup ?
>> I find this configuration approach very convenient so I hope it's the
>> second answer !
> It's a bit of both actually. You'd need to submit a patch to get Nagios
> to accept services linking to empty hostgroups though.
> Andreas Ericsson [email protected]
> OP5 AB www.op5.se
> Tel: +46 8-230225 Fax: +46 8-230231
> This SF.Net email is sponsored by the Moblin Your Move Developer's challenge
> Build the coolest Linux based applications with Moblin SDK & win great prizes
> Grand prize is a trip for two to an Open Source event anywhere in the world
> http://moblin-contest.org/redirect.php? ... =100&url=/
> Nagios-devel mailing list
> [email protected]
L.B.
------=_Part_113405_11789644.1226403818337
Content-Type: text/x-patch; name=hostgroup_empty.patch
X-Attachment-Id: f_fnegnj3f0
Content-Disposition: attachment; filename=hostgroup_empty.patch
IyBkaWZmIC1OcnUgbmFnaW9zLTMuMC41L3hkYXRhL3hvZHRlbXBsYXRlLmMgbmFnaW9zLTMuMC41
X2hvc3Rncm91cGVtcHR5L3hkYXRhL3hvZHRlbXBsYXRlLmMgCi0tLSBuYWdpb3MtMy4wLjUveGRh
dGEveG9kdGVtcGxhdGUuYwkyMDA4LTA2LTIzIDIzOjQzOjIyLjAwMDAwMDAwMCArMDIwMAorKysg
bmFnaW9zLTMuMC41X2hvc3Rncm91cGVtcHR5L3hkYXRhL3hvZHRlbXBsYXRlLmMJMjAwOC0xMC0y
OSAxNzozNzowMy4wMDAwMDAwMDAgKzAxMDAKQEAgLTUxNTMsMTIgKzUxNT
...[email truncated]...
