matthias eble wrote:
>>> Maybe tuning config.cgi to accept host/service names/descriptions
>>> would
>>> be best. With a nice two column table, overview for single
>>> hosts/services would be better. The link could be added to the top
>>> left
>>> box.
>> I can't quite picture what you mean. Are you saying that on the /cgi-
>> bin/extinfo.cgi?type=1&host=hostname screen, a link is in the top left
>> box that is (say) "View Configuration Detail For This Host"?
> yup
>> This
>> would go to extinfo.cgi with a different type id (?) and then print
>> all configuration data, including parents, children, contacts and
>> contactgroups?
> I'd place the logic into config.cgi. That would (if supplied with a
> hostname or hostname+service_description argument) print a nice table
> including links to parents, contacts, check_command, interval,...
> Of course, with the current data structures looking up children will be
> painful in large installations.
Not necessarily. The object config parsing code is already riddled with
#ifdef NSCORE
do_stuff();
#elif defined(NSCGI)
do_other_stuff();
#endif
so we could potentially add this stuff to the CGI's. It's not my itch to
scratch, but I'll accept patches along those lines.
OP5 AB www.op5.se
Register now for Nordic Meet on Nagios, June 3-4 in Stockholm
http://nordicmeetonnagios.op5.org/
on peace.
