Ton Voon wrote:
> On 19 Feb 2007, at 05:57, Ethan Galstad wrote:
>> Thanks Ton - most of these patches were applied to CVS tonight.
>> Exceptions are the notification_level patch, which I'm not sure if
>> I'll
>> implement (yet).
> Great. Thanks!
>> Also, the db upgrade script was modified, as only one
>> script file needs to be executed to bring an older schema up to date.
> I'm guessing from your comment above that you only want a single SQL
> script to upgrade from current version to the latest. However, you'll
> find that you will be writing the same SQL statements in each
> "current version" script.
> FWIW, we've found it easier to have a single section per schema
> version, so if someone is updating from 1.3 to, say, 2.0, there are
> sql statements to bring it from, say, 1.3 to 1.4b2, 1.4b2 to 1.5, 1.5
> to 1.6, 1.6 to 2.0. So each script clearly defines the transition
> from an older schema to the next level. Running all these scripts
> (which is what upgradedb.pl was doing) would then bring you to the
> current level.
> Just my 2 pence worth.
> Ton
It shouldn't be too bad - if all goes well, the DB schema should
stabilize fairly quickly.
Ethan Galstad,
Nagios Developer
Email: [email protected]
