[Nagios-devel] Nagios 4: Registering object relationships in CGIs
--Apple-Mail-22--844770302
Content-Type: text/plain;
charset=us-ascii
We're looking at the latest Nagios 4 branch and have seen an issue where =
the refactoring around object relationships seems to be missing for the =
CGIs. The specific problem is that the contactgroups do not have all the =
members populated, though I think host groups and other relationships =
are affected.
It looks like the Nagios4 code uses a member_list structure which is =
NULL for #ifdef NSCGI, but is set correctly with a linked list for =
#ifdef NSCORE.
The patch below fixes this though I'm not convinced this is the right =
way to fix. It seems to me that the member_list structure should be =
populated correctly for NSCGI.
Ton
filename=nagios_cgi_contactgroups_not_expanded.patch
Content-Type: application/octet-stream;
name="nagios_cgi_contactgroups_not_expanded.patch"
diff -ur nagios-4.0.20130107/xdata/xodtemplate.c nagios-4.0.20130107.working/xdata/xodtemplate.c
--- nagios-4.0.20130107/xdata/xodtemplate.c 2012-12-24 19:56:13.000000000 +0000
+++ nagios-4.0.20130107.working/xdata/xodtemplate.c 2012-12-24 19:57:08.000000000 +0000
@@ -7186,6 +7186,7 @@
int xodtemplate_register_contactgroup(xodtemplate_contactgroup *this_contactgroup) {
contactgroup *new_contactgroup = NULL;
objectlist *list;
+ char *temp_ptr;
/* bail out if we shouldn't register this object */
if(this_contactgroup->register_object == FALSE)
@@ -7200,6 +7201,17 @@
return ERROR;
+#ifdef NSCGI
+ /* Opsview patch: When reading CGIs, the contact groups are not expanded out correctly. We do this manually from
+ the objects.cache, which is reliable as each item here should already be a valid contact.
+ It is okay to do the following member_list as this will be NULL
+ for(temp_ptr = strtok(this_contactgroup->members, ","); temp_ptr; temp_ptr = strtok(NULL, ",")) {
+ add_contact_to_contactgroup(new_contactgroup, temp_ptr);
+#endif
for(list = this_contactgroup->member_list; list; list = list->next) {
xodtemplate_contact *c = (xodtemplate_contact *)list->object_ptr;
add_contact_to_contactgroup(new_contactgroup, c->contact_name);
--Apple-Mail-22--844770302--
