Dear Folks,
The fact that Nag 2.x is a threaded application (uses pthread_Foo())
has certain implications for systems, usually BSD based (in partic
FreeBSD 4.x), that 'struggle' with thread support.
AFAIK, on FreeBSD 4.x systems these threaded applications are either
patched or have thread support disabled or partly so :-
Perl with thread API (>= 5.6. Perls are usually built without thread
support)
mySQL
ntop
Nag 2.x performance may be problematic on such systems.
In fact, Nag 2.x does _not_ SEGV at exit() (vi) when compiled without
embedded Perl support.
It would be good to see how Nag 2.x goes on FreeBSD 5.x with its claimed
improvements to threads (KSEs).
Yours sincerely.
Stanley Hopcroft
tsitc> gdb nagios
GNU gdb 4.18 (FreeBSD)
Copyright 1998 Free Software Foundation, Inc.
GDB is free software, covered by the GNU General Public License, and you
are
welcome to change it and/or distribute copies of it under certain
conditions.
Type "show copying" to see the conditions.
There is absolutely no warranty for GDB. Type "show warranty" for
details.
This GDB was configured as "i386-unknown-freebsd"...Deprecated bfd_read
called at
/usr/src/gnu/usr.bin/binutils/gdb/../../../../contrib/gdb/gdb/dbxread.c
line 2627 in elfstab_build_psymtabs
Deprecated bfd_read called at
line 933 in fill_symbuf
(gdb) set args -v /usr/local/nagios/etc/nagios.cfg
(gdb) r
Starting program: /usr/home/anwsmh/build/nagios-cvs/base/nagios -v
Nagios 2.0a1
Copyright (c) 1999-2004 Ethan Galstad ([email protected])
Last Modified: 11-18-2003
License: GPL
Reading configuration data...
Error in configuration file '/usr/local/nagios/etc/nagios.cfg' - Line
278 (UNKNOWN VARIABLE)
***> One or more problems was encountered while processing the config
files...
directives and data defintions. If you are upgrading from a
previous
version of Nagios, you should be aware that some
variables/definitions
may have been removed or modified in this version. Make sure to
read
Program received signal SIGSEGV, Segmentation fault.
0x281e9da4 in .cerror () from /usr/lib/libc.so.4
(gdb) bt
#0 0x281e9da4 in .cerror () from /usr/lib/libc.so.4
#1 0x2827acbf in _exit () from /usr/lib/libc_r.so.4
#2 0x281e9ca3 in exit () from /usr/lib/libc.so.4
#3 0x8052776 in main (argc=3, argv=0xbfbffb4c, env=0xbfbffb5c) at
nagios.c:434
(gdb)
Not withstanding the comments above, the bt shows that death results
from exit(result);
I can't understand why exit(anything) should die.
/* the config files were okay, so run the pre-flight check */
else{
printf("Running pre-flight check on
configuration data...\n\n");
/* run the pre-flight check to make sure things
look okay... */
result=pre_flight_check();
if(result==OK)
printf("\nThings look okay - No serious
problems were detected during the pre-flight check\n");
else{
printf("\n***> One or more problems was
encountered while running the pre-flight check...\n");
printf("\n");
printf(" Check your configuration
file(s) to ensure that they contain valid\n");
printf(" directives and data
defintions. If you are upgrading from a previous\n");
printf(" version of Nagios, you
should be aware that some variables/definitions\n");
printf(" may have been removed or
modified in this version. Make sure to read\n");
printf(" the HTML documentation
regarding the config files, as well as the\n");
printf(" 'Whats New' section to find
out what has changed.\n\n");
/* clean up after ourselves */
cleanup();
/* exit */
exit(result);
