Stanley Hopcroft wrote:
>>I should be writing less than PIP_BUF bytes, although I'm not
>>specifically checking. In the case where I can see the concatenation of
>>messages it is always less that the max amount. In fact I haven't seen
>>any messages greater than this.
> you won't - all of the IO (both system and Perl) - requires the coder to
> explicity check for errors.
Yep, I understand this. I could be paranoid and check the message length
and truncate if beyond a certain size, but I know these are syslog
messages and are less than the PIP_BUF size by their nature.
>>I am using print to output the message to the pipe as I am using open.
>>If I was using sysopen I guess I'd use syswrite. Is this what you mean?
> This may be useful:
> My understanding is
> 1 print always uses (buffered) stdio; syswrite is simply a badly named
> Perl interface to the system (unbuffered) write() system call.
Presumably as opposed to the perl write function, which I think also
uses buffered I/O.
> Never use print with things like sockets and multi-user pipes.
> 2 sysopen is simply another interface to the open() system call.
> Unlike Perl open, it has no magic (eg read from or to pipes), and lets
> you sepcify file modes and stuff.
> If you haven't already done so, you may like to consider
> 1 ignoring sys?open
> 2 s/print/write()/g
Checking the perldoc in light of your suggestions I found syswrite does
unbuffered I/O. So I'll change the print to syswrite and failing this I
can change $| as in perlfaq5.
Thanks for the help,
Jim
