Re: [Nagios-devel] Nagios3-cvs: Possible bug in additive
Matthias Eble wrote:
> Hi Ethan, hi list,
> I think I found a bug in additive inheritance for escalations.
> here's what the docs say:
> > Service and host escalation definitions can make use of a special rule
> > that combines the features of implied and additive inheritance. If
> > escalations 1) do not inherit the values of their contact_groups or
> > contacts directives from another escalation template and 2) their
> > contact_groups or contacts directives begin with a plus sign (+), then
> > the values of their corresponding host or service definition's
> > contact_groups or contacts directives will be used in the additive
> > inheritance logic.
> with the latests cvs version this doesn't seem work.
> I looked at the source and the problem is that
> xodtemplate_clean_additive_strings() is called before
> xod_template_inherit_object_properties(). But the latter tries to do
> some additive inheritance, too. Unfortunately the + signs are gone then.
> My suggest would be to move xod_template_inherit_object_properties()
> before xodtemplate_clean_additive_strings() so that the inheritance work
> is done before the duplication tasks.
> Matthias
Thanks for the report Matthias. A patch is now in CVS which should
resolve this issue.
Ethan Galstad
Nagios Developer
___
Email: [email protected]
Web: www.nagios.org
