Re: [Nagios-devel] Nagios 4 ignores object_cache_file and log_file
When will RPM's be updated?
Brad
On Sep 16, 2012, at 5:33 PM, "Andreas Ericsson" wrote:
> On 09/16/2012 05:13 PM, Joerg Linge wrote:
>>=20
>> Am 16.09.2012 um 16:27 schrieb Andreas Ericsson :
>>>=20
>>> Well, that's by design. The objects.cache should only be written to onc=
e.
>>> Or do you mean that it gets created but is empty?
>>=20
>> Correct.
>> object_cache_file was created using the wrong path (/usr/local/nagios/va=
r/objects.cache as defined in includes/locations.h instead of /omd/sites/ng=
4/var/nagios/objects.cache defined in nagios.cfg )
>>=20
>> But the file contains just the header.
>>=20
>=20
> Righto. I figured it out and a fix is pushed to both github and to
> svn. Thanks for helping out.
>=20
> --=20
> Andreas Ericsson [email protected]
> OP5 AB www.op5.se
> Tel: +46 8-230225 Fax: +46 8-230231
>=20
> Considering the successes of the wars on alcohol, poverty, drugs and
> terror, I think we should give some serious thought to declaring war
> on peace.
>=20
> Everyone hates slow websites. So do we.
> Make your web apps faster with AppDynamics
> Download AppDynamics Lite for free today:
> http://ad.doubleclick.net/clk;258768047;13503038;j?
> http://info.appdynamics.com/FreeJavaPer ... nload.html
> Nagios-devel mailing list
> [email protected]
