Auto-login?
jpipitone
Auto-login?
Post by jpipitone »
Is there a way to configure NagiosXI to automatically login as a guest user?
When one of our IT staff visits http://nagios.ourcompany.com, we would like them to automatically be logged into the NagiosXI web interface as a read only guest user, similar to how our Nagios 2.9 core functioned.
If a privileged member of the IT staff wishes to login and make changes, they would be able to do so as well.
Thanks for any help.
Joe
-Linux Distribution and version:
32 bit CentOS
-Manual Install of XI
- No SSL
tonyyarusso
Re: Auto-login?
Post by tonyyarusso »
I don't think automatic logins are possible anymore due to some security measures that were put in place that check for a valid session on every page.
Tony Yarusso
Technical Services
___
TIES
Web: http://ties.k12.mn.us/
fao
Re: Auto-login?
Post by fao »
We also very much need the ability to auto-login for guest users, very much
tonyyarusso
Re: Auto-login?
Tony Yarusso
Technical Services
___
TIES
