Re: [Nagios-devel] Distributing plugins
Why complicating with cfengine-setups, or using svn-remote checkouts?=20
I keep my latest script on cvs-rep at nagios host, then I *push* the
latest commits once a day with:=20
=20
for ssh_host in nrpe_host_1 nrpehost_2 ...; do=20
rsync -avuz /path/to/scripts $ssh_host:/path/to/nrpe/scripts
done
YMMV
/AdmirTrakic
-----Original Message-----
[mailto:[email protected]] On Behalf Of Jeffrey
Lensen
Sent: 05 September 2007 17:23
To: Nagios Developers List
Subject: Re: [Nagios-devel] Distributing plugins
We use an SVN repository for our scripts. In addition we have an NRPE
check running on all servers which checks the revision number of the
checkout on that machine by performing a command like "svn info | grep
Revision | awk '{print $2}' ".
If you want to keep the checkout up to date there are a few
possibilities:
- create a crontab entry which runs every night and updates the
repository
- create a check which compares the output of the above check with the
most recent revision, of which you have a checkout on the Nagios
machine. If it doesn't match, you can return a CRITICAL and create an
event handler which does an "svn update"
- keep them up to date manually
Just my 2 cents :)
Jeffrey Lensen
System Administrator Hyves
hyves page: http://skyler.hyves.nl
mail/msn: [email protected]
Tobias Mucke wrote:
> Hi,
> we are building a RPM package with the standard Nagios plugins, some
other plugins from Nagios Exchange and our own plugins. This RPM is
rolled out by Cfengine together with nrpe.cfg.
> This works quite nice and you need a deployment process / tool for
system administration anyway, not only for Nagios plugins.
> If you are interested I could post SPEC file and our Cfengine
configuration for this task.
> Tobias
> --- This SF.net email is sponsored by: Splunk Inc.
> Still grepping through log files to find problems? Stop.
> Now Search log events and configuration files using AJAX and a
browser.
> Download your FREE copy of Splunk now >> http://get.splunk.com/=20
> Nagios-devel mailing list
> [email protected]
> =20
Now Search log events and configuration files using AJAX and a browser.
[email protected]
