[Nagios-devel] Nagios build patch
--------------000306040101010202090809
Content-Type: text/plain; charset=us-ascii; format=flowed
The attached patch makes the following changes to Nagios (CVS current as
of Tue Jun 25 22:25:23 EDT 2002):
(1) Modifies install targets to strip binaries *after* installing them.
This allows one to run 'make install' as root after building Nagios as
an unprivileged user in an NFS mounted filesystem (where root generally
has no write privileges).
(2) Modifies the configure.in script to search for the 'strip' binary.
(3) Adds some missing quotes in configure.in that were causing autoconf
(2.52) to complain.
Enjoy,
-- Lars
Content-Type: image/x.djvu;
name="nagios-build-patch"
Content-Disposition: inline;
filename="nagios-build-patch"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...[email truncated]...
