[Nagios-devel] Double escaping when using $ARGS1$?
Hi!
I wanted to check what should be the correct behaviour.
Given a service and command definition like this:
command_name my_plugin_full
command_line /plugins/my_plugin 'Message with '\''quotes'\'' in'
check_command my_plugin_full
I can see Nagios executes this (from ndo data):
/plugins/my_plugin 'Message with '\''quotes''\' in'
This is what I want because commands are executed by the shell so
escaping of the single quotes is important to preserve the information.
However, given a service and command definition like this:
command_name my_plugin_with_args
command_line /plugins/my_plugin $ARG1$
check_command my_plugin_with_args!'Message with'\''quotes'\'' in'
I can see that Nagios executes a command line of:
/plugins/my_plugin 'Message with '''quotes''' in'
Note that there is no \ anymore. So in order to get the \ into the
command line, I'd need to escape the \ in the argument part of the
service definition.
Is this correct behaviour? I think this is wrong, or at least
inconsistent.
Ton
