[Nagios-devel] [PATCH] Fix for "hosts too" when scheduling
--------------050107050009040708010303
Content-Type: text/plain; charset=ISO-8859-15; format=flowed
This patch just inserts a "trigger-id" field of 0 into the command,
fixing its formatting and thus preventing the Nagios daemon from
rejecting the command as being malformed.
It applies to latest cvs, and, at least in spirit, also to nagios-2.x,
which also needs it to work properly.
OP5 AB www.op5.se
name="nagios-servicegroup-and-hosts-downtime-fix.patch"
Content-Disposition: inline;
filename="nagios-servicegroup-and-hosts-downtime-fix.patch"
diff --git a/cgi/cmd.c b/cgi/cmd.c
index 71439ac..91600ff 100644
--- a/cgi/cmd.c
+++ b/cgi/cmd.c
@@ -2212,7 +2212,7 @@ int commit_command(int cmd){
if(affect_host_and_services==FALSE)
snprintf(command_buffer,sizeof(command_buffer)-1,"[%lu] SCHEDULE_SERVICEGROUP_SVC_DOWNTIME;%s;%lu;%lu;%d;0;%lu;%s;%s\n",current_time,servicegroup_name,start_time,end_time,(fixed==TRUE)?1:0,duration,comment_author,comment_data);
else
- snprintf(command_buffer,sizeof(command_buffer)-1,"[%lu] SCHEDULE_SERVICEGROUP_SVC_DOWNTIME;%s;%lu;%lu;%d;0;%lu;%s;%s\n[%lu] SCHEDULE_SERVICEGROUP_HOST_DOWNTIME;%s;%lu;%lu;%d;0;%lu;%s;%s\n",current_time,servicegroup_name,start_time,end_time,(fixed==TRUE)?1:0,duration,comment_author,comment_data,current_time,servicegroup_name,start_time,end_time,(fixed==TRUE)?1:0,duration,comment_author,comment_data);
+ snprintf(command_buffer,sizeof(command_buffer)-1,"[%lu] SCHEDULE_SERVICEGROUP_SVC_DOWNTIME;%s;%lu;%lu;%d;0;%lu;%s;%s\n[%lu] SCHEDULE_SERVICEGROUP_HOST_DOWNTIME;%s;%lu;%lu;%d;%lu;%s;%s\n",current_time,servicegroup_name,start_time,end_time,(fixed==TRUE)?1:0,duration,comment_author,comment_data,current_time,servicegroup_name,start_time,end_time,(fixed==TRUE)?1:0,duration,comment_author,comment_data);
break;
default:
--------------050107050009040708010303--
