--0016e6dd86273b3ef80497dc2ffa
Content-Type: text/plain; charset=ISO-8859-1
OK, Andreas,
I raised a patch on the tracker at http://tracker.nagios.org, issue number
0000184.
It is running on my Nagios production environment and is working fine until
now.
Thanks a lot,
Rodney.
On Mon, Dec 20, 2010 at 3:50 PM, Andreas Ericsson wrote:
> On 12/20/2010 05:52 PM, Rodney Ramos wrote:
> > Hi, Jochen,
> > Thank you again. I think that you found where the problem is, I mean, t=
he
> > base/checks.c::is_host_result_fresh() code.
> > I change the lines in the checks.c as below:
> > =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=
=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=
> > FROM: Lines 2439 - 2440
> > if(temp_host->freshness_threshold=3D=3D0)
> freshness_threshold=3D(temp_host->check_interval*interval_length)+temp_ho=
st->latency+additional_freshness_latency;
> > TO:
> > if(temp_host->freshness_threshold=3D=3D0){
> > if(temp_host->state_type=3D=3DHARD_STATE ||
> > temp_host->current_state=3D=3DSTATE_OK)
> > else
> freshness_threshold=3D(temp_host->retry_interval*interval_length)+temp_ho=
> > It is working well, as expected. My retry interval is 1 minute and host=
s
> are
> > taking about 2 minutes to change SOFT states.
> > The logs are:
> > BEFORE the changes:
> > [1292854105] Warning: The results of host 'host1' are stale by 0d 0h 0m
> 1s
> > (threshold=3D0d 0h 5m 15s). I'm forcing an immediate check of the host=
> > [1292857824] Warning: The results of host 'host1' are stale by 0d 0h 0m
> 1s
> > [1292859117] Warning: The results of host 'host1' are stale by 0d 0h 0m
> 52s
> > AFTER the changes:
> > [1292859297] Warning: The results of host 'host1' are stale by 0d 0h 0m
> 59s
> > (threshold=3D0d 0h 1m 38s). I'm forcing an immediate check of the host=
> > [1292859417] Warning: The results of host 'host1' are stale by 0d 0h 0m
> 31s
> > (threshold=3D0d 0h 1m 22s). I'm forcing an immediate check of the host=
> > [1292859597] Warning: The results of host 'host1' are stale by 0d 0h 0m
> 47s
> > (threshold=3D0d 0h 1m 44s). I'm forcing an immediate check of the host=
> > So, I=B4d like to known the developers opinion. It=B4s a bug or it=B4s =
not?
> It definitely seems like a bug.
> > Are
> > you intending to change the source code? If not I will have to change i=
t
> > myself always when a new Nagios version is released.
> Or you can go with door nr 3 and submit a patch to make the necessary
> changes. I won't have time to look into this until god knows when, but I
> do have time to apply patches and run some rudimentary tests which, along
> with your assertation that it works as per expectations in your network,
> should suffice to get it into the first release after I get the patch.
> Thanks.
> Andreas Ericsson [email protected]
> OP5 AB www.op5.se
> Tel: +46 8-230225 Fax: +46 8-230231
> Considering the successes of the wars on alcohol, poverty, drugs and
> terror, I think we should give some serious thought to declaring war
> on peace.
Content-Type: text/html; charset=ISO-8859-1
OK, Andreas,I raised a patch on the tracker at <a href=3D"http://tr=
acker.nagios.org/" class=3D"e
...[email truncated]...
