[Nagios-devel] =?utf-8?b?W1BBVENIXSBuZWJtb2RzLmM6MTU1OjY6IHdhcm5p?=
As we are not checking the return of neb_load_all_modules() at nagios.c, we don't need to have a var to store the return of neb_load_module().
OK? Comments?
--- base/nebmods.c (revision 1973)
+++ base/nebmods.c (working copy)
@@ -152,10 +152,9 @@
/* load all modules */
int neb_load_all_modules(void) {
nebmodule *temp_module = NULL;
- int result = OK;
for(temp_module = neb_module_list; temp_module; temp_module = temp_module->next) {
- result = neb_load_module(temp_module);
+ neb_load_module(temp_module);
return OK;
