On Fri, 2006-09-22 at 12:26 -0700, Andrew Tjang wrote:
> Hello Everyone,
>=20
> I am trying to get Nagios to read from traces. I'm having difficulty =
on
> figuring out where to begin.=20
>=20
> I want to do this because I don't have direct access to the machines
> i'll be monitoring. I need to periodically ship the monitored data =
from
> the hosts to the nagios machine, parse the files and then update =
nagios.
> The parsing part I think i can do fine. It's the part that involves
> modifying Nagios to read from file rather than query hosts that I need
> help with.=20
If I understood you correctly, I think the best solution for you is to
write the contents of the file with monitored data to nagios.cmd pipe.
Once you have parsed the file you can figure out how to properly write
the service check result to be processed by nagios via command pipe.
> I'd like to keep the same config file format, but just modify the
> monitoring sections to read from file based on those configs. Is there
> any place you could recommend that I start looking?
You won't even bother this. You should look for external commands
documentation: (if you're using nagios 2.x)
http://nagios.sourceforge.net/docs/2_0/extcommands.html
> Thank you in advance for your assistance,
> -Andrew
HTH,
Marcel
AVISO: A informa=E7=E3o contida neste e-mail, bem como em qualquer de =
seus anexos, =E9 CONFIDENCIAL e destinada ao uso exclusivo do(s) =
destinat=E1rio(s) acima referido(s), podendo conter informa=E7=F5es =
sigilosas e/ou legalmente protegidas. Caso voc=EA n=E3o seja o =
destinat=E1rio desta mensagem, informamos que qualquer divulga=E7=E3o, =
distribui=E7=E3o ou c=F3pia deste e-mail e/ou de qualquer de seus anexos =
=E9 absolutamente proibida. Solicitamos que o remetente seja comunicado =
imediatamente, respondendo esta mensagem, e que o original desta =
mensagem e de seus anexos, bem como toda e qualquer c=F3pia e/ou =
impress=E3o realizada a partir destes, sejam permanentemente apagados =
e/ou destru=EDdos. Informa=E7=F5es adicionais sobre nossa empresa podem =
ser obtidas no site http://sobre.uol.com.br/.
NOTICE: The information contained in this e-mail and any attachments =
thereto is CONFIDENTIAL and is intended only for use by the recipient =
named herein and may contain legally privileged and/or secret =
information. If you are not the e-mail=B4s intended recipient, you are =
hereby notified that any dissemination, distribution or copy of this =
e-mail, and/or any attachments thereto, is strictly prohibited. Please =
immediately notify the sender replying to the above mentioned e-mail =
address, and permanently delete and/or destroy the original and any copy =
of this e-mail and/or its attachments, as well as any printout thereof. =
Additional information about our company may be obtained through the =
site http://www.uol.com.br/ir/.
