[Nagios-devel] FEATURE REQUESTS for OCSP/OCHP and Process Perf Data
This is a MIME message. If you are reading this text, you may want to
consider changing to a mail reader or gateway that understands how to
properly handle MIME multipart messages.
--=__PartBC991F52.0__=
Content-Type: text/plain;
charset=us-ascii
I have run into a situation which has prompted these feature requests. If a
particular type of service fails (probably do to a reboot of the associated
server), we need to remount some NCPFS mounts. If the remote host is still
rebooting when the remount event handler fires off, the remount will fail and
won't ever be run again.
Can there be an option to have an Event Handler run after hard-state retries
(like notifications) instead of just on state changes and soft-error states?
Can OCSP/OCHP and Process Perf Data be altered to be like Event Handlers in
that there is a Global version of it, but a specific command can be specified
for a particular host or service.
I'm open to suggestions and corrections.
Marlo
NOTICE: This email message is for the sole use of the
intended recipient(s) and may contain confidential and
privileged information. Any unauthorized review, use,
disclosure or distribution is prohibited. If you are not the
intended recipient, please contact the sender by reply email
and destroy all copies of the original message.
Content-Type: text/html;
charset=us-ascii
Content-Description: HTML
I have run into a situation which has prompted these feature requests. If a particular type of service fails (probably do to a reboot of the associated server), we need to remount some NCPFS mounts. If the remote host is still rebooting when the remount event handler fires off, the remount will fail and won't ever be run again.
Can there be an option to have an Event Handler run after hard-state retries (like notifications) instead of just on state changes and soft-error states?
Can OCSP/OCHP and Process Perf Data be altered to be like Event Handlers in that there is a Global version of it, but a specific command can be specified for a particular host or service.
Marlo
NOTICE: This email message is for the sole use of the intended recipient(s) and may contain confidential and privileged information. Any unauthorized review, use, disclosure or distribution is prohibited. If you are not the intended recipient, please contact the sender by reply email and destroy all copies of the original message.
--=__PartBC991F52.0__=--
