status file remains behind, so the CGIs think everything is fine.
Can either or you run the unstripped nagios binary (as a foreground
process) under gdb, like so:
gdb --args /path/to/unstripped/nagios /usr/local/nagios/etc/nagios.cfg
Type 'r' in gdb to start the program running. When it segfaults you
should be able to use 'bt' to get a backtrace. Send me that output, as
it will help me solve the problem.
hindrek murdsalu wrote:
> I've also noticed some strange behavior, like Nagios PID not existing in
> processes or any other nagios related processes running when doing ps
> axfu | grep nagios (save for the grep itself) while it seems to display
> everything on the webinterface. When I for example request to schedule a
> service/host check, it won't commit of course. Reloading can't kill the
> old PID, starts regardless but soon the processes drop again.
>> Hi, I upgraded Nagios 3b3 to 3b4 this morning and Nagios shutdown
> after a few minutes.Let me know if I can help because I don't have any
> message in the logs, I don't know what I can send.
>> I switched back to nagios 3b3 and it works now. (Well it's not
> production, but a kind of
Ethan Galstad,
Nagios Developer
Email: [email protected]
