Re: [Nagios-devel] user groups for cgi's
You know, the more I look at it the more that I think you are right... I
can probably do everything that I am after with trickery on the config
side... I was thinking about doing something a little more sophisticated,
but I guess I can make my management software more sophisticated :)
Thanks - Chuck
Marc Powell wrote:=20
>> -----Original Message-----
>> From: [email protected] [mailto:nagios-devel-
>> [email protected]] On Behalf Of Chuck Pierce
>> Sent: Wednesday, February 07, 2007 10:56 AM
>> To: Nagios Developers List
>> Subject: Re: [Nagios-devel] user groups for cgi's
>>=20
>> Sorry, I should have been a little more specific... I am talking
>about
>> limiting to more than just the cgi. I am talking about limiting
>access to
>> hosts within the cgi.
>>=20
>> Example:
>> if using status.cgi?hostgroup=3Dall you would only get a listing of the
>> actual
>> hosts that you have access to.
>Unless I'm still not understanding, that's exactly what authentication
>provides. We use it extensively, providing restricted views for 1175
>contacts. Nagios looks at the REMOTE_USER variable set by htaccess to
>determine who is logged in. Hosts and services are only shown that they
>are contacts for. For hostgroup views, I believe that you must have
>permission to see all hosts within a hostgroup to view the hostgroup.
>Try it and see. I feel confident it's what you're looking for.
>As far as not sending notifications, disable them with the following in
>your template or contact definition --
> service_notification_period none
> host_notification_period none
>Marc=20
>Using Tomcat but need to do more? Need to support web services, security?
>Get stuff done quickly with pre-integrated technology to make your job
>easier.
>Download IBM WebSphere Application Server v.1.0.1 based on Apache =
Geronimo
>http://sel.as-us.falkag.net/sel?cmd=3Dl ... 63057&dat=
=3D121642
>_______________________________________________
>Nagios-devel mailing list
>[email protected]
>https://lists.sourceforge.net/lists/lis ... gios-devel
--=20
Email: [email protected]
Home: 615.370.4116
Cell: 615.477.6966
