Re: [Nagios-devel] Docs 3.0: clusters.html
Thomas Guyot-Sionnest wrote:
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
> On 11/11/07 03:38 AM, Wolfgang Barth wrote:
>> Hi Ethan,
>> as with nagios-plugins-1.4.10, check_cluster uses the same command line
>> interface as check_cluster2 from ./contrib in earlier versions.
>> So, if check_cluster2 is renamed to check_cluster and will be regularly
>> installed, your documentation (cluster.html) did not match.
>> Ton, can you confirm this?
> Good catch! Although we enhanced the official check_cluster (Support
> thresholds ranges among others) it's fully backwards-compatible.
> Ethan please update the doc :) check_cluster in the official
> distribution appeared at release-1.4.9.
> http://nagios.sourceforge.net/docs/2_0/clusters.html
> http://nagios.sourceforge.net/docs/3_0/clusters.html
> Thanks,
> Thomas
Thanks for the info on this. I'll get the change made in CVS shortly.
HTML and PDF docs are recreated from CVS about every 4 hours, so they
should reflect the change later today.
Ethan Galstad
Nagios Developer
___
Email: [email protected]
Web: www.nagios.org
