Re: [Nagios-devel] nagios silently stops
---moq1144046473182d1cabf4c48b4bcecefc934361e0aa
Content-Type: text/plain; charset=ISO-8859-1
A have switched flapping detection off and after that nagios works=0Ajust f=
ine.=0A Quoting Ton Voon : On 31 Mar 2006, at 10:06, Vadim Korsak wrote:=
=0A Nagios 2.1 have stopped some times. Last entry in log till it stops =0A=
=0A - SERVICE FLAPPING ALERT:=0A grep -B 1 "2.1 starting..." /var/log/nagio=
s/nagios.log=0A [1143723946] SERVICE FLAPPING ALERT: _net-n-liepaja-srv;DIS=
K C: =0A free space;STARTED; Service appears to have started flapping (20.=
5% =0A=0A change >=3D 20.0% threshold)=0A [1143790405] Nagios 2.1 starting.=
.. (PID=3D6671)=0A --=0A [1143792340] SERVICE FLAPPING ALERT: _net-n-liepaj=
a-srv;DISK C: =0A free space;STARTED; Service appears to have started flap=
ping (21.1% =0A=0A change >=3D 20.0% threshold)=0A [1143792757] Nagios 2.1 =
starting... (PID=3D11656)=0A --=0A [1143793487] SERVICE FLAPPING ALERT: _ne=
t-n-liepaja-srv;DISK C: =0A free space;STARTED; Service appears to have st=
arted flapping (21.6% =0A=0A change >=3D 20.0% threshold)=0A [1143793561] N=
agios 2.1 starting... (PID=3D24024)=0A --=0A [1143794252] SERVICE FLAPPING =
ALERT: _net-n-liepaja-gw;PING =0A gateway;STARTED; Service appears to have=
started flapping (24.2% =0A change >=3D 20.0% threshold)=0A [1143794282] =
Nagios 2.1 starting... (PID=3D2723)=0A --=0A [1143795613] SERVICE FLAPPING =
ALERT: _net-n-liepaja-srv;DISK C: =0A free space;STARTED; Service appears =
to have started flapping (21.3% =0A=0A change >=3D 20.0% threshold)=0A [114=
3795722] Nagios 2.1 starting... (PID=3D27191)=0A Nagios itself starts flapp=
ing ;)=0A Vadim,=0A Which platform are you running on? Which configure opti=
ons did you =0A build with?=0A When it happens again, can you send a pstre=
e output (want to see if =0A=0A nagios has forked other processes - maybe h=
anging on an external =0A command). For each nagios process, can you run a=
n strace to see what=0A =0A bit of the code it is currently hanging on.=0A =
Ton=0A http://www.altinity.com=0A T: +44 (0)870 787 9243=0A F: +44 (0)845 2=
80 1725=0A Skype: tonvoon=0A =0A=0ALinks:=0A------=0A[1] mailto:ton.voon@a=
ltinity.com=0A
Content-Type: text/html; charset=ISO-8859-1
A have switched flapping detection off and after that nagios works just fin=
e.
Quoting Ton Voon <[email protected]>:=
On 31 Mar 2006, at 10:06, Vadim =
Korsak wrote:
Nagios 2.1 h=
- SERVICE F=
LAPPING ALERT:
grep -B 1 "2.1 starting..." /var/log/=
nagios/nagios.log
[1143723946] SERVICE FLAPPING ALERT: _net-n-liepaja=
-srv;DISK C:
free space;STARTED; Service appears to have started fl=
apping (20.5%
[1143790405] Na=
gios 2.1 starting... (PID=3D6671)
[1143792340] SERVICE FLAPP=
ING ALERT: _net-n-liepaja-srv;DISK C:
free space;STARTED; Service a=
ppears to have started flapping (21.1%
change >=3D 20.0% thresho=
ld)
[1143792757] Nagios 2.1 starting... (PID=3D11656)
[1143793487] SERVICE FLAPPING ALERT: _net-n-liepaja-srv;DISK C:
fre=
e space;STARTED; Service appears to have started flapping (21.6%
ch=
[1143793561] Nagios 2.1 starting... (PI=
D=3D24024)
[1143794252] SERVICE FLAPPING ALERT: _net-n-liepa=
ja-gw;PING
gateway;STARTED; Service appears to have started flappin=
g (24.2%
[1143794282] Nagios =
...[email truncated]...
