Re: [Nagios-devel] WG: NDO 1.4b7 - nagios_hosts Field Aliases in
--Apple-Mail-96-558716012
Content-Type: text/plain;
charset=us-ascii
On 14 Apr 2011, at 20:21, Ton Voon wrote:
>=20
> On 14 Apr 2011, at 11:47, Michael Friedrich wrote:
>=20
>> Mies, Christian wrote:
>>>=20
>>> Hi Michael,
>>> thank you for the fast answer. After looking at documentation I set =
up
>>> =20
>>> retail_nonstatus_informatoin=3D0 in my Host Template.=20
>>> I've looked at the retension.dat, but there still standing the name =
before changing Alias Value.
>>=20
>> afaik that setting does not affect the attributes being saved. there =
was a patch in svn as proposed fix just in 3.2.2 - i've already removed =
that in icinga 1.3.x because it's annoying and buggy.=20
>>=20
http://nagios.svn.sourceforge.net/viewv ... vision=3D=
1447
>=20
> This issue has just been raised to me in older versions of Opsview as =
well, so I thought I'd look into this here.
>=20
> I can't see why display_name and alias are saved to retention.dat as =
retention.dat is meant to hold data that changes over time (and I don't =
believe these values are dynamically updatable).
>=20
> So if no one raises an objection, I'm going to back out this change =
from trunk tomorrow.
I've reverted this in trunk now. Thanks to Michael for finding the =
original solution.
Ton
Content-Type: text/html;
charset=us-ascii
On 14 Apr 2011, at 20:21, Ton Voon wrote:On 14 Apr 2011, at 11:47, Michael Friedrich wrote:
Hi Michael,
thank you for the fast answer. After looking at documentation I set up
retail_nonstatus_informatoin=0 in my Host Template.
I've looked at the retension.dat, but there still standing the name before changing Alias Value.
removed that in icinga 1.3.x because it's annoying and buggy.
http://nagios.svn.sourceforge.net/viewv ... n=1447This issue has just been raised to me in older versions of Opsview as well, so I thought I'd look into this here.I can't see why display_name and alias are saved to retention.dat as retention.dat is meant to hold data that changes over time (and I don't believe these values are dynamically updatable).So if no one raises an objection, I'm going to back out this change from trunk tomorrow.I've reverted this in trunk now. Thanks to Michael for finding the original solution.Ton
--Apple-Mail-96-558716012--
