Gerhard Lausser wrote:
> Hi Ethan,
> i tested the current cvs code and it reported me (unjustified) circular
> dependencies. I think this patch will help:
> Greetings from Munich,
> Gerhard
> --- nagios-cvs/common/objects.c 2006-09-18 19:03:50.000000000 +0200
> +++ nagios-consol/common/objects.c 2006-10-13 19:17:03.064383605 +0200
> @@ -4119,7 +4119,7 @@
> for(temp_sd=servicedependency_list;temp_sd!=NULL;temp_sd=temp_sd->next){
> /* only check parent dependencies */
> - if(dep->master_service_ptr==temp_sd->dependent_service_ptr)
> + if(dep->master_service_ptr!=temp_sd->dependent_service_ptr)
> continue;
> if(check_for_circular_servicedependency_path(root_dep,temp_sd,dependency_typ
> e)==TRUE)
Thanks Gerhard! I'll get this patch (and the corresponding one for host
dependencies) in CVS shortly.
Ethan Galstad,
Nagios Developer
Email: [email protected]
