No, i don't use this option. Default is the group nagios, but you must cre=
ate a group with nagcmd with members nagios and the user from your webserv=
er. This in write in the documantion. Better was then as dafault group nag=
cmd.
Bye
Michael
-----Urspr=FCngliche Nachricht-----
Von: Nagios Developers List
Gesendet: 02.05.07 11:53:22
An: Nagios Developers List
Betreff: Re: [Nagios-devel] Bin in make install-commandmode
On 02/05/07 02:53 AM, Michael Lubben wrote:
> Hi Ethan,
>=20
> i have found a little bug in "make install-commandmode". When i excuted=
this command, follow instruction i can see on the display:
>=20
> /usr/bin/install -c -m 755 -o nagios -g nagios -d /usr/local/nagios/var/=
rw
> chmod g+s /usr/local/nagios/var/rw
>=20
> For the external commandfile is set the group nagios. That is not right,=
the group must be nagcmd.
Are you using --with-nagios-group=3Dnagcmd in your configure arguments=3F
Thomas
This SF.net email is sponsored by DB2 Express
Download DB2 Express C - the FREE version of DB2 express and take
control of your XML. No limits. Just data. Click to get it now.
http://sourceforge.net/powerbar/db2/
=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F
Nagios-devel mailing list
[email protected]
https://lists.sourceforge.net/lists/lis ... gios-devel
=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F
SMS schreiben mit WEB.DE FreeMail - einfach, schnell und
kostenguenstig. Jetzt gleich testen! http://f.web.de/=3Fmc=3D021192
