> Yves Mettier wrote:
>> Just wondering if the bug I noticed about nagios crashing with -d and =
without -d...
>> If open if used without O_CREAT, it will not create the file.
>> But why should this be different when using -d and when not using -d ?
> It shouldn't. Have you tried strace'ing it?
Yes and this is how I noticed that it was not crashing without -d.
I also tried with -d and strace -ff but I noticed nothing interesting.
The mistake I made is that I removed the files I generated with strace, b=
ecause maybe
you would have found what goes wrong.
If you find nothing, and if I manage to reproduce the bug (I also need to=
rewrite the
config files for that), I can send you more info.
For now, I falled back to nagios-1.2 for other bugs that I could not repr=
oduce and
generate a bug report.
Yves
--=20
- Homepage - http://ymettier.free.fr - http://www.logicacmg.com -
- GPG key - http://ymettier.free.fr/gpg.txt -
- Maitretarot - http://www.nongnu.org/maitretarot/ -
- GTKtalog - http://www.nongnu.org/gtktalog/ -
