Re: [Nagios-devel]
Re: [Nagios-devel]
Am Freitag, 18. Mai 2007 10:01 schrieb Ingo Lantschner:
>=20
> Hello,
Hi Ingo,
> may be I have more luck here ... I have a problem compiling 3.0a4 on =20
> a machine, where 3.0a3 just compiled fine before.
> Pls. see below for details - thanks in advance. Ingo
> > when compiling nagios 3.0a4 on Ubuntu Server 6.06.1 LTS I get this:
> > $ ./configure --enable-embedded-perl --with-perlcache --with-command-
> > group=3Dnagcmd
> > D_FILE_OFFSET_BITS=3D64 -I/usr/lib/perl/5.8/CORE -DHAVE_CONFIG_H -
> > DNSCORE -c -o checks.o checks.c
> > checks.c: In function =91run_async_service_check=92:
> > checks.c:688: error: (first use in this function)
> > checks.c:688: error: (Each undeclared identifier is reported only once
> > checks.c:688: error: for each function it appears in.)
> > make[1]: *** [checks.o] Error 1
> > make[1]: Leaving directory `/home/ingo/tmp/nagios-3.0a4/base'
> > make: *** [all] Error 2
> > Compiling 3.0a3 just worked on this machine - so I guess all
> > dependencies are met.
The same problem on my side if nagios is compiled with "--enable-embedded-p=
erl --with-perlcache"
Can you please compile without this options ?
Just a test to verify the situation. =20
J=F6rg
