NRPE and PAE kernel?
dsdonut
Post by dsdonut »
I'm new to Nagios XI.
I'm trying to install NRPE on my RHEL 5 servers, but I'm not having any success because I'm running the PAE kernel.
When trying to run the NRPE install script, it just quits telling me that the PAE kernel is not supported. Is there any way around that?
These servers run an application that is not written for a 64 bit OS, yet they have 12GB RAM, hence the need for the PAE kernel.
tonyyarusso
Re: NRPE and PAE kernel?
Post by tonyyarusso »
Ha, that's probably my doing. What's your output from 'uname -r'?
Tony Yarusso
Technical Services
___
TIES
Web: http://ties.k12.mn.us/
dsdonut
Post by dsdonut »
uname -r is:
2.6.18-238.5.1.el5PAE
thanks for taking a look at this.
tonyyarusso
There's a fresh agent tarball up now that should fix your problem.
Tony Yarusso
Technical Services
___
TIES
dsdonut
Post by dsdonut »
The new package worked just fine.
Thanks for your help!
rdedon
Post by rdedon »
Feel free to post again if you have any additional questions or issues (or find more bugs! ;))
Thanks!
Rene deDon
Technical Team
___
Nagios Enterprises, LLC
Web: http://www.nagios.com
