This is a multi-part message in MIME format...
------------=_1105928662-48281-228
Content-Disposition: inline
As a postscript,
On Mon, Jan 17, 2005 at 12:52:48PM +1100, Stanley Hopcroft wrote:
> (FWIW, the SEGV comes from Perl whether called from C or from Perl; it
> is not the C code in checks.c that is causing this; the fault is in
> p1.pl or in libperl in the Perl port on this system. It seems strange
> that a Perl program can cause Perl to SEGV)
The SEGV also occurs on Linux (2.4 kernel/5.8.0 threaded Perl). So it
appears to be a Perl problem.
Yours sincerely.
Stanley Hopcroft
IP Australia
Ph: (02) 6283 3189 Fax: (02) 6281 1353
PO Box 200 Woden ACT 2606
http://www.ipaustralia.gov.au
Content-Type: text/plain; name="disclaimer.txt"
Content-Disposition: inline; filename="disclaimer.txt"
MIME-Version: 1.0
X-Mailer: MIME-tools 5.415 (Entity 5.415)
This message contains privileged and confidential information only
for use by the intended recipient. If you are not the intended
recipient of this message, you must not disseminate, copy or use
it in any manner. If you have received this message in error,
please advise the sender by reply e-mail. Please ensure all
e-mail attachments are scanned for viruses prior to opening or
using.
------------=_1105928662-48281-228--
