[Nagios-devel] Nrpe and reiserfs
------=_NextPart_000_0251_01C659C6.58F696F0
Content-Type: text/plain;
charset="us-ascii"
Hi Ethan,
i stumbled over a bug in reiserfs, when i was desperately trying to find out
why an include_dir= statement in my nrpe.cfg was ignored.
In the read_config_dir function you wrote:
#ifdef _DIRENT_HAVE_D_TYPE
/* only process normal files */
if(dirfile->d_type!=DT_REG)
continue;
#endif
which is completely correct.
BUT:
- Linux defines _DIRENT_HAVE_D_TYPE
- readdir for a reiserfs ALWAYS returns DT_UNKNOWN as d_dtype
so always the continue statement will be executed and the configfile will be
ignored.
I made a patch which uses stat and the S_ISREG and S_ISDIR macros instead of
d_type, which also should work on systems without _DIRENT_HAVE_D_TYPE.
Greetings from Munich,
Gerhard
Content-Type: application/octet-stream;
name="nrpe-2.5.reiserfs.patch"
filename="nrpe-2.5.reiserfs.patch"
diff -Naur nrpe-2.5/src/nrpe.c nrpe-2.5.reiserfs/src/nrpe.c=0A=
--- nrpe-2.5/src/nrpe.c 2006-04-06 21:30:00.207859567 +0200=0A=
+++ nrpe-2.5.reiserfs/src/nrpe.c 2006-04-06 22:00:26.379158709 +0200=0A=
@@ -510,6 +510,7 @@=0A=
char config_file[MAX_FILENAME_LENGTH];=0A=
DIR *dirp;=0A=
struct dirent *dirfile;=0A=
+ struct stat buf;=0A=
int result=3DOK;=0A=
int x;=0A=
=0A=
@@ -523,19 +524,18 @@=0A=
/* process all files in the directory... */=0A=
while((dirfile=3Dreaddir(dirp))!=3DNULL){=0A=
=0A=
+ /* create the full path to the config file or subdirectory */=0A=
snprintf(config_file,sizeof(config_file)-1,"%s/%s",dirname,dirfile->d_nam=
e);=0A=
+ config_file[sizeof(config_file)-1]=3D'\x0';=0A=
+ stat(config_file, &buf);=0A=
+=0A=
/* process this if it's a config file... */=0A=
x=3Dstrlen(dirfile->d_name);=0A=
if(x>4 && !strcmp(dirfile->d_name+(x-4),".cfg")){=0A=
=0A=
-#ifdef _DIRENT_HAVE_D_TYPE=0A=
/* only process normal files */=0A=
- if(dirfile->d_type!=3DDT_REG)=0A=
+ if (! S_ISREG(buf.st_mode))=0A=
continue;=0A=
-#endif=0A=
-=0A=
- /* create the full path to the config file */=0A=
e);=0A=
- config_file[sizeof(config_file)-1]=3D'\x0';=0A=
=0A=
/* process the config file */=0A=
result=3Dread_config_file(config_file);=0A=
@@ -545,18 +545,13 @@=0A=
break;=0A=
}=0A=
=0A=
/* recurse into subdirectories... */=0A=
- if(dirfile->d_type=3D=3DDT_DIR){=0A=
+ if(S_ISDIR(buf.st_mode)) {=0A=
=0A=
/* ignore current, parent and hidden directory entries */=0A=
if(dirfile->d_name[0]=3D=3D'.')=0A=
continue;=0A=
=0A=
- /* create the full path to the config directory */=0A=
e);=0A=
-=0A=
/* process the config directory */=0A=
result=3Dread_config_dir(config_file);=0A=
=0A=
@@ -564,7 +559,6 @@=0A=
if(result=3D=3DERROR)=0A=
break;=0A=
}=0A=
-#endif=0A=
}=0A=
=0A=
closedir(dirp);=0A=
------=_NextPart_000_0251_01C659C6.58F696F0--
