--7AUc2qLy4jB3hD7Z
Content-Disposition: inline
We have RCS files within (subdirectories of) the Nagios configuration
directories. Since these files don't have a ".cfg" suffix, they should
be ignored by Nagios. However, Nagios _sometimes_ treats these files as
if they were directories and bails out because it can't opendir() them.
This happens because
1) only the file name but not the full path is passed to the stat() call
which is done for checking the type of a non-cfg file[1], and then
2) the return value of this stat() call is interpreted the wrong way
round: "!=0" is treated as "success" and therefore "stat_buf" will be
read. This is also done for an earlier stat() call[2] (which is not
related to this bug though).
The attached patch fixes these problems.
Holger
[1] xdata/xodtemplate.c:422
[2] xdata/xodtemplate.c:399
PGP fingerprint: F1F0 9071 8084 A426 DD59 9839 59D3 F3A1 B8B5 D3DE
--7AUc2qLy4jB3hD7Z
Content-Disposition: attachment; filename="skip-non-cfg.diff"
Index: xodtemplate.c
RCS file: /cvsroot/nagios/nagios/xdata/xodtemplate.c,v
retrieving revision 1.99
diff -u -r1.99 xodtemplate.c
--- xodtemplate.c 2 Aug 2005 23:58:26 -0000 1.99
+++ xodtemplate.c 8 Oct 2005 00:38:26 -0000
@@ -351,13 +351,12 @@
/* process all files in a specific config directory */
int xodtemplate_process_config_dir(char *dirname, int options){
- char config_file[MAX_FILENAME_LENGTH];
+ char file[MAX_FILENAME_LENGTH];
DIR *dirp;
struct dirent *dirfile;
int result=OK;
int x;
char link_buffer[MAX_FILENAME_LENGTH];
- char file_name_buffer[MAX_FILENAME_LENGTH];
char linked_to_buffer[MAX_FILENAME_LENGTH];
struct stat stat_buf;
ssize_t readlink_count;
@@ -383,19 +382,19 @@
/* process all files in the directory... */
while((dirfile=readdir(dirp))!=NULL){
+ /* create /path/to/file */
+ snprintf(file,sizeof(file),"%s/%s",dirname,dirfile->d_name);
+ file[sizeof(file)-1]='\x0';
/* process this if it's a config file... */
x=strlen(dirfile->d_name);
if(x>4 && !strcmp(dirfile->d_name+(x-4),".cfg")){
- /* create the full path to the config file */
- snprintf(config_file,sizeof(config_file)-1,"%s/%s",dirname,dirfile->d_name);
- config_file[sizeof(config_file)-1]='\x0';
#ifdef _DIRENT_HAVE_D_TYPE
/* only process normal files and symlinks */
if(dirfile->d_type==DT_UNKNOWN){
- x=stat(config_file,&stat_buf);
- if(x!=0){
+ x=stat(file,&stat_buf);
+ if(x==0){
if(!S_ISREG(stat_buf.st_mode) && !S_ISLNK(stat_buf.st_mode))
continue;
@@ -407,7 +406,7 @@
#endif
/* process the config file */
- result=xodtemplate_process_config_file(config_file,options);
+ result=xodtemplate_process_config_file(file,options);
/* break out if we encountered an error */
if(result==ERROR)
@@ -419,8 +418,8 @@
if(dirfile->d_type==DT_UNKNOWN || dirfile->d_type==DT_DIR || dirfile->d_type==DT_LNK){
- x=stat(dirfile->d_name,&stat_buf);
- if(x!=0){
+ if(x==0){
if(!S_ISDIR(stat_buf.st_mode) && !S_ISLNK(stat_buf.st_mode))
continue;
@@ -436,16 +435,12 @@
if(dirfile->d_type==DT_LNK || (dirfile->d_type==DT_UNKNOWN && S_ISLNK(stat_buf.st_mode))){
- /* copy full path info to link buffer */
- snprintf(file_name_buffer,sizeof(file_name_buffer)-1,"%s/%s",dirname,dirfile->d_name);
- file_name_buffer[sizeof(file_name_buffer)-1]='\x0';
- readlink_count=readlink(file_name_buffer,link_buffer,MAX_FILENAME_LENGTH);
+ readlink_count=readlink(file,link_buffer,MAX_FILENAME_LENGTH);
/* Handle special case with maxxed out buffer */
if(readlink_count==MAX_FILENAME_LENGTH){
#ifdef NSCORE
- snprintf(temp_buffer,sizeof(temp_buffer)-1,"Error: Cannot follow symlink '%s' - Too big!\n",file_name_buffer);
+ snprintf(temp_buffer,sizeof(temp_buffer)-1,"Error: Cannot follow symlink '%s' - Too big!\n",file);
temp_buffer[sizeof(temp_buffer)-1]='\x0';
write_to_logs_and_console(temp_buffer,NSLOG_CONFIG_ERROR,TRUE);
#endif
@@ -455,7 +
...[email truncated]...
