Re: [Nagios-devel] nsca-2.9 compatability
Eric and I discusses this problem this morning and we'll be rolling back
the MAX_PLUGINOUTPUT_LENGTH to 512 to maintain compatibility with older
agents.
This is particularly important for Windows addons like NagEventLog,
which will break with the new version of NSCA.
Look for a patch and a new release from Eric soon.
Ethan Galstad
Andrew Widdersheim wrote:
> I haven't looked at NRDP much more than you have but it sounds like it
> would be a fix to many of NSCA's short comings. The problem for us is
> the chore of switching everything over in one shot.
> We don't do that much passively so the check results queue feature is
> actually an extra bonus for us in the upgrade. We are actually more
> interested in the longer output. If there is an easy way to make this
> more compatible for with older versions than great. If not we can plan a
> large upgrade of everything or a cut over to NRDP. We just have a
> problem now and were looking for a quick solution without breaking
> already existing stuff.
> -Andrew W.
> Date: Wed, 11 Jan 2012 15:38:44 -0800
> From: [email protected]
> To: [email protected]
> CC: [email protected]
> Subject: Re: [Nagios-devel] nsca-2.9 compatability
> On 1/11/12 11:16 AM, Andrew Widdersheim wrote:
> I wanted to use Mike Lindsey's new features in nsca-2.9 but found
> that clients on 2.7.2 were not able to communicate after updating
> the server. I found this on the Nagios bug tracker:
> http://tracker.nagios.org/view.php?id=78
> From what I'm reading it's not possible to have a client and server
> compiled with different MAX_PLUGINOUTPUT_LENGTH. Has this been fixed
> at all and I'm just not finding it?
> As far as I'm aware, there's no easy fix for this. If you cannot
> upgrade your clients, then you can recompile the nsca binary with
> MAX_PLUGINOUTPUT_LENGTH set back to 512. That should let you use the
> checkresult directory feature, without breaking compatibility with older
> clients.
> I'll take another look at the source and see if any options jump out at
> me, but I don't know how much effort I should put into it - I think
> Andreas is actively working on a Better Solution.
> Mike Lindsey
> RSA(R) Conference 2012
> Mar 27 - Feb 2
> Save $400 by Jan. 27
> Register now!
> http://p.sf.net/sfu/rsa-sfdev2dev2
> Nagios-devel mailing list
> [email protected]
