Patrick Proy wrote:
> Hi,
> Did anybody test the patch ?
Like I told you before you went along hacking up this patch, it
addresses a very limited usergroup. I believe most networks have at the
most two or three snmp communities/username-password-pairs.
> Patrick
>>Envoyé : mardi 21 décembre 2004 16:04
>>À : 'nagios-devel'
>>Objet : [Nagios-devel] RE: SNMP community in host configuration
>>Hi,
>>I updated my patch. Works with today's CVS : "patch -p0 >patch_nag_snmp_2004.12.21.patch" :
>>- added "snmp_community" in host/template definition,
>>accessed by $SNMPCOMMUNITY$ macro.
>>- Changed the "hostuser" macro in "hostmacro" :
>> - in host/template definition : "hostmacro SomeData"
>> - In services : "$HOSTMACRO$"
>>- In nagios.cfg, the option is now named "host_snmp_login",
>>same syntax.
>>As usual, feedbacks are welcome !
>>Patrick
>>nagios AT proy.org
>>>How to patch :
>>> - it work with the CVS version of 19 Dec 2004
>>> - in the "nagios-cvs" directory : "patch -p0 >
>>patch_nag_snmp.patch"
>>>Note : only works with template based config files.
>>>I tested it on Linux only for now, but as nothing is platform
>>>specific, it should be OK.
>>>Here are the modified files (if a new CVS version is out) :
>>>- common/objects.c base/config.c base/nagios.c base/utils.c
>>>include/common.h include/objects.h include/nagios.h.in
>>>xdata/xodtemplate.c xdata/xodtemplate.h
>>>What it does :
>>>1) SNMP for each host
>>>You can put snmp information in three ways :
>>>- In the host definition :
>>> snmp_version # stores snmp version
>>> snmp_login # stores snmp login (for v3)
>>> snmp_pass # stores snmp password for v3 or
>>>community for
>>>v1
>>>None of them are compulsory of course
>>>- In the host template (will then only overwrite what's not in host
>>>definition)
>>> Same syntax
>>>- In the nagios.cfg file :
>>> snmp_login=1,,/
>>> snmp_login=3,,,/
>>> This is generic snmp login for networks : it will be
>>put in the host
>>>snmp info if the host hasn't got any, and if it's address
>>matches the
>>>network/mask definition. Mask with best precision will be chosen
>>>first.
>>> Example :
>>> snmp_login=1,private,10.100.0.0/16
>>> snmp_login=3,login1,pass1,10.100.0.3/32
>>> This means :
>>> - on the 10.100.0.0/16 network : v1, private
>>> - for the 10.100.0.3 host : v3 : login1, pass1
>>> 10.100.3.45 : will get v1, private
>>> 10.100.0.3 : will get v3, login1, pass1
>>>- The information is available as macro :
>>> - $SNMPVERSION$
>>> - $SNMPLOGIN$
>>> - $SNMPPASS$
>>>2) user variables for host
>>>- Each host can have up to 10 user variables (you can put more or
>>>less, just by modifying a number in the code), specified in its
>>>definition :
>>> hostuser
>>> example :
>>> hostuser3 SomeInformation
>>>- Of course, host templates can have hostuser too. (will
>>be put in
>>>host definition is the host doesn't have the hostuser already).
>>>- Available as macro :
>>> $HOSTUSER$
>>>TODO :
>>>- I forgot snmp v2c : maybe 2 will be okay but it would be
>>cleaner to
>>>have "2c".
>>>- Hostuser are from 0->9..., maybe it would be cleaner to put 1->10.
>>>Please test it and give me feedback !
>>>Patrick
>>>nagios AT proy.org
> The SF.Net email is sponsored by: Beat the post-holiday blues
> Get a FREE limited edition SourceForge.net t-shirt from ThinkGeek.
> It's fun and FREE -- well, almost....http://www.thinkgeek.com/sfshirt
> Nagios-devel mailing list
> [email protected]
OP5 AB www.op5.se
Lead Developer
