Re: [Nagios-devel] nagios -v not counting all warnings
2009/12/19 Jim Avery :
> 2009/12/17 Ton Voon :
>> Can you get a minimal config that displays this behaviour? I'll add it
>> to the tests in CVS.
> Yes I will do in the next few days. =A0I'm sorry I didn't have any spare
> time yesterday.
>> Should it be counted in the warnings or is it just an informational
>> message?
> If it were just informational, I suppose you could simply change the
> "Warning" to "Information" and have done with it. =A0Personally I'd
> rather it remain a warning (and gets counted) as it does point to a
> genuine mistake in the config.
Okay here's the minimal config (I'm assuming you already have simple
templates for generic-host and generic-service):
command_name check_dummy
command_line $USER1$/check_dummy $ARG1$
define hostgroup{
hostgroup_name test
alias test - hosts used for testing
use generic-host
host_name test
alias test - Host used for testing new service checks in Nagios
address 10.123.123.123
hostgroups +test
parents localhost
define service
host_name test
service_description test
check_command check_dummy!0 "test always succeeds"
define service
host_name test
When I run nagios -v against a nagios.cfg which reads this config, I get:
Warning: Duplicate definition found for service 'test' on host
'test' (config file '/usr/local/nagios/etc/objects/test/services.cfg',
starting on line 1)
which is fair enough as the service is indeed defined twice, but in
the totals at the end I get:
Total Warnings: 0
Total Errors: 0
Note this behaves the same whether the second service is defined using
directive "host_name test" or "hostgroup_name test".
hth,
Jim
