Sorry for multiple release candidates, but I fixed two more issues with the CGIs that are very closely related to issues fixed in the 3.4.5rc1 tarball.
The release has also been bumped to 3.5.0 because of an ABI change. (It should have been bumped prior to 3.4.5rc1.) The downtime structure had a member added to help resolve the downtime notification problem. This means that modules will need to be recompiled to use this version.
You can download the 3.5.0rc1 tarball from http://sourceforge.net/projects/nagios/ ... z/download.
Feel free to compile it and try it (on a test system, please). The 3.4.5 candidate did not generate much feedback and I'm hoping no news is good news. The changes between 3.4.5rc1 and 3.5.0rc1 are relatively minor, so I don't plan to wait long until releasing 3.5.0.
The complete changelog since 3.4.4 is as follows:
* Fixed bug #403: The "configuration" page of the webui doesn't use entity encoding when displaying the "command expansion" item (Eric Stanley)
* Fixed bug #424: Nagios Core 3.4.4 seg fault (core dump) on restart after removing config for running service (Eric Stanley)
* Updated CGI utility functions to support UTF-8 characters (Eric Stanley)
* Fixed bug where selecting Command Expansion from Configuration CGI page would display commands instead (Eric Stanley)
* Fixed bug #369: status.cgi crashes with segfault when there are german ulauts (äöüß) in the hostname or the servicename (Eric Stanley)
* Fixed bug #418: Scheduled Downtime Notifications Resent On Nagios Restart/reload (Eric Stanley)
Eric Stanley
___
Developer
Nagios Enterprises, LLC
Email: [email protected]
Web: www.nagios.com
